How to wire a sub
0 Members and 1 Guest are viewing this topic. Read 2000 times.
fsilahua
How to wire a sub
« on: 7 Mar 2024, 03:54 pm »
Introducing myself.
My question is,. How to wire a pair of monoblock amps to one subwoofer? Thank you in advance
Re: How to wire a sub
« Reply #1 on: 7 Mar 2024, 03:58 pm »
I will move this topic to the Lab Circle for your convenience.
opnly bafld
« Reply #2 on: 7 Mar 2024, 05:30 pm »
What amplifiers?
mick wolfe
« Reply #3 on: 7 Mar 2024, 05:35 pm »
Introducing myself.
It all depends on the pre-amp, amps and the subwoofer you're using. If you using a pre-amp with a second set of line outs, I'd simply do line level hookup to the sub. If you're attempting speaker level hookup, always best to consult the amp and subwoofer manufacturers for best advice. This especially if your mono amps are class d.
« Reply #4 on: 7 Mar 2024, 07:01 pm »
Check if your mono amp allow this kind of connection, I can say in advance the British Musical Fidelity E3 or E5 dont like and will explode itself.
fsilahua
« Reply #5 on: 7 Mar 2024, 07:17 pm »
Preamp: Benchmark HPA4
Monoblocks: Parasound JC1
Sub: SVS PB-2000Pro
opnly bafld
« Reply #6 on: 8 Mar 2024, 12:17 am »
Sub: SVS PB-2000Pro
Are you using the XLR outputs on the HPA4 to the JC1s?
If you can use both XLR and RCA outputs simply use the RCA outputs to the subwoofer.
If you want to run speaker wire there are several ways.
Wire to sub and then to speakers, wire to speakers and then to sub, 2 wires from JC1, one to speakers and one to sub.
Do you have room for another subwoofer?
Run one from left channel and the other from the right channel.
fsilahua
« Reply #7 on: 8 Mar 2024, 05:20 pm »
Thank you all for your help,
- I'm going to first try to run the 2nd output line level from the preamp to the sub first. If that doesn't work, I'll run from amps to spekers-sub.
- Unfortunately, the room I have is limited, but makes sense to have two one sub per monoblock.
Thanks again
timind
  • permanent vacation
« Reply #8 on: 8 Mar 2024, 06:33 pm »
When I had the HPA4, I ran the XLR output into the Benchmark AHB2, and the RCA output into my SB3000. Worked perfectly.
Mitsuman
  • Diamond Tone Junkie
« Reply #9 on: 8 Mar 2024, 07:03 pm »
You should update your gallery.  :D
