0 Members and 1 Guest are viewing this topic. Read 4655 times.
I have eventually put GK-1 into a case. At the last minute, I decided to go seperate for preamp as well -- I will put a source selector into a seperate case.I don't think this layout is the one I like best. What I don't like is the horizontal PCB orientation so that the signal wires are longer. As I have no hum at all, I can live with it.One thing I need to address is the vibration. Even though the transformers and PCB are mounted on seperate bars, I can feel slightly the vibration on the PCB caused by transformers. If a screw driver is used with one end against the ear and the other on the PCB to hear it, I would say the vibration is loud, which I believe will cause microphonic effects on the tubes. Any suggestions to isolate the transformer vibrations?Try this, First place rubber gromets through all the transformer mounting holes in the chassis.Get a bolt then place a flat washer and then a rubber washer. Place this through the transformer mounting tab, then add another rubber washer and then mount the transformer. Then add another rubber washer and another flat washer and then put on the nut and tighten gently.BE SURE TO SOLDER A GROUND WIRE ONTO THE TRANSFORMER FRAME TO ENSURE SAFETY. THE MOUNTING TAB IS A GOOD PLACE FOR IT.Andrew
Another isolation approach, is to suspend the circuit board from rubber bands.
Hi Larry or anyone.A few questions about the two isolation box used for the transformers. I plan to do the same for my AKSA100 transformer and wonder if the transformer will generate any heat. Is aluminum better then steel? TIA,Sam
I got some rubber top caps from Bunnings warehouse, which is used in toilet flush, and sat the transformers on top of them (two for each) with slightly tighted bolts with rubber washers. All the weights are on the two rubber top caps, which are very elastic. I picked up my screw driver again and touched it to the PCB. Deadly quiet! ...
