Bryston 4bcubed spec question
0 Members and 1 Guest are viewing this topic. Read 734 times.
JFRMusic
« on: 4 Mar 2024, 02:46 am »
Hi
New here but definitely interested in either the 3b or 4b cubed amps. As someone with a bad back I’m concerned about weight. On the Bryston site the weight of the amps is listed as 35 lbs and 42 lbs respectively. However I found two older reviews that said the 4b was 63 lbs. can you confirm the spec?  And to those who own the 4b have you found it easy to get home, unbox and setup by yourself?
