SOLD Jensen Transformers ISO-MAX Speaker to XLR Line Level Converter
0 Members and 1 Guest are viewing this topic. Read 945 times.
Hear Clifford Brown
Sold.
Asking $125, retail $207 with shipping.
Ships from 98332.
I used this to connect subwoofers to an amp with no XLR output jacks.
Model #SP-2SX, a two channel speaker to line level converter that lets you convert the output from any amplifier's speaker terminals to balanced XLR. It is speaker level in, XLR cables out. If you don't want to use the included SpeakON connectors for the speaker level in, there are barrier strip connectors on the opposite side of the box (pictured).
From the website
https://www.jensen-transformers.com/product/sp-2sx/
Converts any speaker or amplifier output to line level
Delivers exceptionally low distortion down to 20 Hz
Ruler flat frequency response from 5 Hz to 20 kHz
Plug and play easy to use, no power required
Passive interface does not require any power to work.
Inside are two Jensen high performance transformers that isolate the output to eliminate hum and buzz caused by ground loops while they eliminate issues with ‘bridged’ and ‘class D‘ power amp outputs.
There is a link to a PDF manual on the website.
Buyer pays shipping, 10x7x5 box, 2 lbs.  Payment with PayPal F&F.
More positive feedback on Audiogon going back to 2002. User name jeff_ss.
« Last Edit: 29 Feb 2024, 02:55 pm by Hear Clifford Brown »
