Samsung TV Optical Out to DAC???
0 Members and 1 Guest are viewing this topic. Read 3051 times.
Zuman
« on: 26 Feb 2024, 03:06 pm »
Hi, All. Home Theater is not my thing, but I have a fairly low-end 65" Samsung TV that shares a room with my "quite nice" 2-channel system. The other day I decided to run an optical cable from the Toslink-out jack of the TV to one of the Optical-In jacks of my hifi's Okto Research dac8 Stereo DAC.
After ensuring that the Optical-Out on the TV was selected and the Optical-In on the DAC was active, I turned up the amp volume but all I heard was a strange crackling sound...not quite static, but certainly not distorted TV program sound either.
Is TV Optical-Out to DAC Optical-In a valid connection approach?
BCRich1
Re: Samsung TV Optical Out to DAC???
« Reply #1 on: 26 Feb 2024, 03:13 pm »
Hi,
You have to go to the Audio setting of the TV and set the output to PCM.
That should fix it.
Cheers….Mike
Zuman
« Reply #2 on: 26 Feb 2024, 03:32 pm »
Duh...THANK YOU!
(That did it!).
