***SOLD***: Stealth Audio Cloude 99 solid silver Power Cable
0 Members and 1 Guest are viewing this topic. Read 962 times.
Early B.
***SOLD***
For sale is the Stealth Audio Cloude 99 1M power cable in very good condition. The Cloude 99 is made of 99.997% pure solid silver, 001 inch think flat wires (ribbons). No real dielectric is used - at least, in the conventional sense: each of the silver ribbons is gently spiraled inside a flexible (but strong) transparent Helium filled 1/4 inches OD tubing (STEALTH para-vacuum technology*). The tubing touches only the very thin edges of the silver wire, and the flat part of the wire is surrounded by Helium only; each tube is strictly airtight to prevent Helium from leaking out and preserve the silver from oxidation. When such construction is measured, the dielectric constant is very close to 1.0 - (vacuum) - and the closest up, solid Teflon, being 2.2 to 2.5 depending on the Teflon type (all other known solid dielectric have higher constants; the closer the dielectric constant to 1.0 - the better for the subjective "speed" perception). The Cloude 99 is extremely soft and flexible, and literally looks like a cloud!
Features:
•   99.997% pure solid silver flat (low inductance) wire;
•   Para-Vacuum dielectric**
•   over 1 inch overall cord diameter;
•   Proprietary STEALTH clear shell AC plug with solid silver contacts;
•   Proprietary STEALTH IEC receptacle with solid silver contacts;
This is an extra power cable and it's no longer needed, hence the sale. Retail price was $3,900. My price is $495 with free shipping in USA.
« Last Edit: 22 Feb 2024, 05:05 pm by Early B. »
