0 Members and 1 Guest are viewing this topic. Read 7313 times.
Please post your impressions and results with what ever you choose.
A soffit style bass trap would definitely look better and take up less wall space than a 2' x 4' x what ever thickness cross corner trap
Another thing to consider is pipe insulation cut in quarters of which the rigid fiberglass has a nominial diameter of 24" and is 6" thick. That would cover 18" of wall and 18" of ceiling and it would mount flush to both... it would also look good. Another thought... if it had FRK, then it would essentially be a diffusor as well. Any thoughts on that?
I was thinking more along the lines of having the the pipe insulation only at the wall ceiling corner, and have it wrap around the room (much like a curved soffit). ;
BTW, Knauf makes pipe insulation that is 6" thick, has a density of 6 lbs/cf, has a foil face and a nominal diameter of 24".
