Bryston BP2.5 cubed discontinued
0 Members and 1 Guest are viewing this topic. Read 3266 times.
Pincher
« on: 10 Feb 2024, 09:12 pm »
Hi,
It seems the 2.5 cubed is discontinued.  Is a new unit on the way, or was it just cut from production?  I was thinking to replace my 20 year old NAD power amp with the 2.5 cubed, the 3 cubed it more $ :(
https://bryston.com/discontinued/
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston BP2.5 cubed discontinued
« Reply #1 on: 10 Feb 2024, 10:22 pm »
HI
Yes discontinued.
No plans for an immediate replacement.
james
GrooveControl
« Reply #2 on: 11 Feb 2024, 04:05 am »
Yikes, the B135 too.  So no integrated amps at this time?
AllanS
« Reply #3 on: 11 Feb 2024, 05:26 am »
Hi,
If their websites can be trusted it’s available from both Audio Advisor and Moon Audio.
« Reply #4 on: 11 Feb 2024, 01:37 pm »
We have a new Integrated on the way called the Bi-200
james
Pincher
« Reply #5 on: 11 Feb 2024, 04:18 pm »
Hi
Thanks for the info.  I'll use my Bryston BHA-1 as a pre-amp.
Komoyuki
« Reply #6 on: 11 Feb 2024, 08:20 pm »
james
Hi James. Any information at this time ?
« Reply #7 on: 11 Feb 2024, 08:23 pm »
Yes we are just waiting to finalize the Phono stage and we should be ready to start production.
james
Pincher
« Reply #8 on: 12 Feb 2024, 03:49 pm »
Hi James.
Is (was) there a sonic difference between the 2.5 and the 3?
Dan
« Reply #9 on: 12 Feb 2024, 06:31 pm »
The circuitry is the same - the 3B has double the power supply size and double the output transistors.
james
gbaby
« Reply #10 on: 26 Feb 2024, 03:58 pm »
It is sad the 2.5b has been discontinued. It was a nice amp for those with high efficiency speakers. My speakers play 96db with a 1 watt input at 1 meter. I cannot crank it up pass -25 db on the volume knob on my SP3.
alexone
« Reply #11 on: 29 Feb 2024, 10:03 am »
james
…James,
any news about the Bi200??
thanx,
al.
« Reply #12 on: 29 Feb 2024, 12:22 pm »
Yes we are just finalizing the design - should have a prototype to show soon - here is what it will look like.
Komoyuki
« Reply #13 on: 29 Feb 2024, 01:43 pm »
Hi James.
it would be interesting to have a sticky post to discuss the development of the Bi200 insteadof this discontinued BP135 thread. What do you think?
« Reply #14 on: 29 Feb 2024, 01:56 pm »
Hi - sure we can do that
james
moonblue77
« Reply #15 on: 3 Mar 2024, 11:31 am »
This is timely.
I'm looking to acquire a used nB3 to replace a pair of 20 yr old Tag McLaren M125 monos.
I can get a 6yr old 2.5B3 with warranty, or a 4B3 without warranty (user has lost receipt and it's an early model with no manufacture date on rear).
My setup is: BP26/MPS-2, BDP2, BDA2, Linn LP12, PMC OB1i speakers. I play mostly at low level due to busy household/shared space. Listening space is small @ 2m width x 3.5m length.
I know it's not ideal to buy without listening, but I can return either for full refund if I'm not happy. Also, I know no one can tell me which will sound better. Reaching out because I just don't know which one to choose. Any words of wisdom?
Dan H
« Reply #16 on: 3 Mar 2024, 03:01 pm »
Based on your listing habits and listening room dimensions alone I can't imagine you'd need anything more powerful than the 2.5B3.
FWIW, my 2.5B3, front ended with a BR-20, drives a pair of Focal Aria 936's (92db) to very satisfying levels in a space considerably larger than yours. I doubt you could go wrong with either the 2.5B3 or the 4B3, but the 2.5 sure seems to fit your current needs.
moonblue77
« Reply #17 on: 3 Mar 2024, 10:36 pm »
Dan, as you're an owner of a 2.5b3 I appreciate this info. It supports my gut feel having done some research. I probably wouldn't take advantage of the 4B3 extra power, as you state.
