Determining the -6dB point of an in-line filter
0 Members and 1 Guest are viewing this topic. Read 1268 times.
mlundy57
« on: 27 Jan 2024, 11:49 pm »
If a first order in-line filter is designed to be -3dB at 100Hz, it would be -9dB at 50Hz. How do you determine where it will be -6dB since the drop is not linear?
jmimac351
Re: Determining the -6dB point of an in-line filter
« Reply #1 on: 28 Jan 2024, 01:32 am »
« Last Edit: 5 Dec 2025, 06:53 pm by jmimac351 »
HAL
« Reply #2 on: 28 Jan 2024, 01:20 pm »
For a single pole high pass filter you can use the equation:
C=1/(2*Pi*R*F-3dB), so for a R=47000 Ohm input impedance, and a F-3dB=100Hz, C= 0.0338uF.
Linear Technologies has a free version of SPICE for circuit simulation.  I used it to plot the frequency response of that filter.  I put the cursor at the -6.02dB point as close as possible with the system.  The -6dB point is ~58Hz.
jmimac351
HAL
« Reply #4 on: 28 Jan 2024, 04:20 pm »
The 0.0338uF would be 33.8nF or 33800pF.
If you start with the original uF value and multiply x1000, then it is nF, do it again and it is pF.
jmimac351
« Reply #5 on: 28 Jan 2024, 04:45 pm »
Got it! I see the mistake I made... Should have entered "47" into the calculator instead of 47,000, given that I had the value set to "Kohms".  Thank you.  :duh:
jmimac351
« Reply #6 on: 28 Jan 2024, 05:36 pm »
Here's what I got for a spreadsheet for capacitor value / formula for 100hz high pass filter... or given whatever values are entered into the yellow cells.
« Last Edit: 29 Jan 2024, 08:20 am by jmimac351 »
mlundy57
« Reply #7 on: 30 Jan 2024, 05:15 pm »
Thanks Rich,
I've downloaded the software. Now I have to learn how to use it to get what you are showing. Then I can manipulate the parameters. Based on your example, the -6 point is 84% of the way through the octave, not 50% like it would be if it was linear instead of logarithmic. It will be interesting to see if the -6 point is 84%  of the way through the octave with other -3 points between 40Hz and 200Hz.
HAL
« Reply #8 on: 30 Jan 2024, 07:45 pm »
Mike,
Glad to help.
Rich
