0 Members and 1 Guest are viewing this topic. Read 3182 times.
Not really looking for a sonic advantage, just negatives.
BTW for finishing the boards, most likely will use some (ugly) black Duratex I have laying around, which should seal up the wood.
BB situation is definitely weird right now. First shipping problems, now Ukraine situation. As of last week, one distributor I use has opted out of selling it altogether. Has some kind of similar thing in 1/2", although I have not seen it. Sounds like North American ply that probably has softwood core where BB has all same thickness birch cores. I'm guessing primarily used for cabinet drawers.Without getting too political, the US has sanctions against Russian, evidently including Baltic Birch. I've read they use a run around through China, who knows. Don't think things will change any time soon.I did check with another distributor I've used, and they have both 5x5 and 4x8 in 18mm BB/BB grade. A few sheets of B/BB. Not cheap though, 4x8-$152, 5x5-$122. I queried as to future supply and really didn't have an answer. Only that they have 1000+ sheets in their system now.Where are you JK?, They have several warehouses.
I'm not familiar with the PAP design. Can you make the L&R baffles from one 4x8 sheet? I always bought 4x8 sheets of 3/4" from my supplier, don't know if it was officially Baltic birch but it had more plys than construction plywood and suited my purpose. The 16 ply doesn't have any voids like construction plywood. The $60 sheets may have only one good face or both faces will have patches and "footballs," my supplier called it cabinet grade, it was perfect for the inside of projects that would never be seen (or covered in Duratex). Store the sheets horizontally (8' side on the floor) against a flat wall or laying on a very flat surface, never upright at an angle.Birch plywood gradeshttps://www.woodworkerssource.com/blog/woodworking-101/tips-tricks/your-ultimate-guide-to-baltic-birch-plywood-why-its-better-when-to-use-it/I would skip the MDF, make the baffles all plywood. There is a reason all open baffle speakers are made from baltic birch ply, it works without surprises.I have also used ApplePly plywood made in Eugene, OR.Why? Sand the Baltic birch to #220 and apply a clear sealer. No stain, birch is notoriously difficult to stain, the grain changes direction and gets blotchy. Interior wood doesn't have to be sealed, it will hang out just fine unfinished but will get dirty and waterspot. Some cabinetmakers just waxed their furniture, it's a lot of work and not durable but can look great. A coat of shellac and then wax, old school.
The fellow I talked to today said it was "B" grade (?) furniture quality, but 13 ply. We had a kitchen remodel done a few years back and the contractor left some extra 3/4" shelving. It appears to be Baltic, but not quite....probably the same stuff.I live in Virginia Beach, there is a supplier in Norfolk (next door) that I bought my other "real" BB from. Wasn't open today, will try again on Monday.
MDF/Baltic birch laminate is guaranteed to warp
So my question to the group...anyone see a problem with keeping the 25" width? I know Pure Audio uses a 21-1/2" width, Perry Marshall Bitches Brew (which I could upgrade these baffle drivers to later) uses 21-22". Steve Decware's medium barrels are much wider. It would be nice not have to cut the slabs at all, except for the driver holes. I'm good there, with router and bits. So is 25" too wide, or no biggie?
