Timeframe for RMA number request?
0 Members and 1 Guest are viewing this topic. Read 1757 times.
Highendfool
  • It is what you think.
« on: 9 Jan 2024, 06:42 pm »
James,
I was wondering how long it takes to get a reply from a request for RMA# thru your web site?
  • The Demo is Everything!
    • http://www.bryston.com
Re: Timeframe for RMA number request?
« Reply #1 on: 9 Jan 2024, 09:03 pm »
HI
I would send it direct to Mike - [email protected]
james
Highendfool
« Reply #2 on: 9 Jan 2024, 09:07 pm »
HI
james
Thanks James!
Out of interest, what's the answer?
Highendfool
« Reply #3 on: 12 Jan 2024, 06:24 pm »
HI
james
Hi again James!
I emailed him on the 9th
Guessing he's very busy.
Are you in touch with him??
Would love to get this moving!
« Reply #4 on: 12 Jan 2024, 07:33 pm »
I will check again
james
Highendfool
« Reply #5 on: 12 Jan 2024, 08:11 pm »
I will check again
james
Much appreciated, thank you.
zeeman
« Reply #6 on: 12 Jan 2024, 08:19 pm »
James,
You can generate your own RMA in about a minute through the new Bryston service portal.  Good for warranty AND non warranty items:
Canada:  rma.bryston.ca
US:  rma.bryston.com
Highendfool
« Reply #7 on: 12 Jan 2024, 08:27 pm »
US:  rma.bryston.com
If that's true, why is there no link on Bryston's web site ?  BTW...bryston.ca defaults to Bryston.com, so I wouldn't trust keying into the site you shared. Thanks anyway!
zeeman
« Reply #8 on: 12 Jan 2024, 08:49 pm »
No link likely because it's a brand new feature.  I've personally used it, and can vouch for it.  But, suit yourself.
Highendfool
« Reply #9 on: 12 Jan 2024, 08:54 pm »
Just curious about a couple of things..
1. How did you know about this site if it's so new that Bryston hasn't even put a link on their webpage yet?
2. If you've used it, and it's legit, why didn't James recommend it?
Highendfool
« Reply #10 on: 22 Jan 2024, 01:32 pm »
US:  rma.bryston.com
You are correct zeeman. This is a new portal for RMA generation. I’ve been instructed to use it by Bryston service and I apologize if I seemed a bit paranoid and doubted your statement!
I still think it needs work, but it’s functional.  Thanks for your input! ✌🏻
