0 Members and 1 Guest are viewing this topic. Read 5289 times.
Exactly what is a BBE 282 ?
I used some of the BBE Sonic Maximizers in the past, they're excellent providing they mate up correctly with your preamp.I tried one with a Sonic Frontiers SFL-2 and it caused my speakers to flutter, I'm not sure what it was doing.With old Carver and Sunfire gear the results were really impressive.
I still don't know what they do. What is a audible effect of these things? Their sales blurb make it sound like a loudness switch on an old receiver, boosting low and high frequencies.
So it's a more up to date version of something I had in my car in high school...
Ok. A recording should never out of phase from one range to another. They are all recorded as they arrive at the microphone, and they all generated simultaneously and travel at the same speed. Phase issues are usually at the speaker, often from multiple driver speakers with crossovers. If you are changing phase relationships from lows, mids, and treble it will certainly change the sound. And perhaps you can improve on a particular crossover designer... but that's like redesigning a crossover. It's not for the faint of heart or the inexperienced. I do appreciate the offer, and if I'm in Austin soon, I'll drop you a note. It's always educational to hear other systems.
From my original post "The Sonic Maximizer adjusts the phase relationships between the low, mid and high frequencies by adding progressively longer delay times to lower frequencies." It works slightly differently than, but has a similar effect to, the Aphex Aural exciter (though you may not know what that is either).A loudness switch boosts high and low frequencies according to the Fletcher-Munson curve (https://en.wikipedia.org/wiki/Equal-loudness_contour). Thus, a loudness control does not change phase relationships - it boosts highs and lows because based on how humans perceive frequencies at lower volumes. To answer your question "What is a audible effect of these things?" I can describe it but it will be meaningless because the effect is subtle - I find instruments more clearly defined in the soundstage. If you have a Guitar Center or other music store nearby, check if they sell BBE and ask if you can hear it in action.Like with many things in audio, it is hard to describe but easier to hear it.
The processors of Barcus Berry Elecronics are usually used in Radio Stations to enhance the music and in musical instruments I had only see it used in electric violins.
