Preamp tube rolling
0 Members and 1 Guest are viewing this topic. Read 5092 times.
bunkertoy
Preamp tube rolling
« on: 5 Jan 2024, 12:28 am »
Hi Everyone,
Happy New Year.
I'm looking to get some tubes to roll through my VTL 2.5 preamp. I recently got some new speakers, so I wanted to play with some tubes.
I'm doing my research to find some decent tubes.
My Question is : I have 4 tubes in my preamp 2-12AU7(Gain section), 2 - 12AT7(Buffer section).
Should I focus on the Gain section 12AU7 tubes or the Buffer section 12AT7 ?. I believe the answer is Gain section. Should I even bother getting nice tubes for the buffer section ?
Thoughts and opinions always welcome.
Re: Preamp tube rolling
« Reply #1 on: 5 Jan 2024, 12:49 am »
Hi Everyone,
Happy New Year.
The tubes are senile?
VTL factory tubes usually are quite good.
IMO replace the tubes when they get old.
Constant tube changes made looseness in the sockets pins.
bunkertoy
« Reply #2 on: 5 Jan 2024, 01:06 am »
I'm currently running Tung-sol in the gain section. Been there for a year without swamping
JakeJ
« Reply #3 on: 5 Jan 2024, 01:24 am »
Hello and Welcome bunkertoy,
The gain position will have the greatest effect on the sound quality.  The buffer position will make very little difference.
Nice preamp, BTW.
bunkertoy
« Reply #4 on: 5 Jan 2024, 02:01 am »
Thanks Jake,
 that's what I thought. Just makes it easier to spend on the 12AU7 instead of AT7. much appreciate you confirming my thoughts.
Thanks I'm loving the VTL 2.5 preamp, only wish it had balanced connections. My Bel Canto 3.7 DAC  performs best with XLR outs.
Cheers
Craig Young
« Reply #5 on: 13 Sep 2025, 08:31 am »
Running my Freya+ with the original tung-sol 6SN7's for a couple of years now. I wanted to have spares so I replaced them with psvane quad 6SN7's. I never expected this terrific sound change. I am hearing major changes to my music, the bass is so much louder. Maybe I'm fooling myself with mind tricks?
