FS: GR Research Designed XCS Center Channel
0 Members and 1 Guest are viewing this topic. Read 1888 times.
apstoltz
« on: 2 Jan 2024, 12:05 am »
Up for sale is. GR Research designed center channel in a light Moho finish. Big center channel that would be the main staple in your ht setup. Speaker sounds great and is in good condition . Here are the specs.
Looking for local sale in central Indiana.
$150
System: Two way, three driver directradiating system, sealed enclosure
Drivers: 1″ treated fabric dome and two custom 6.5″ curvilinear shaped treated paper cone woofers with polymer chassis
Crossover: 2100Hz, 2nd order Frequency Response: 65 Hz to 20 KHz (± 3 dB) Impedance: 8 Ohms nominal
Efficiency: 90.5 dB (@ 1 watt / 1 meter)
Dimensions: Horizontally Oriented: 8.5″ H x 20.0″ W x 15.5″ D; Vertically
Oriented: 20.0″ H x 8.5″ W x 15.5″ D
Weight: 33lbs each
« Last Edit: 29 Jan 2024, 08:36 pm by apstoltz »
apstoltz
Re: FS: GR Research Designed XCS Center Channel
« Reply #1 on: 29 Jan 2024, 08:36 pm »
Price adjustment and willing to ship. Thanks.
