Cornet2 cap size question.
0 Members and 1 Guest are viewing this topic. Read 1351 times.
rotcoddam
« on: 4 May 2005, 01:02 am »
At C202, can I use a .056uf 500v. instead of the .047uf?
hagtech
    • http://www.hagtech.com
« Reply #1 on: 4 May 2005, 06:01 am »
It will throw the EQ off a little bit.  You could probably compensate by making R204 and R205 lower.  It's a bitch to calculate because it involves the tube rp, load, other EQ resistors, and the loading of following stage.  I leave this exercise to the reader.
jh :|
rotcoddam
« Reply #2 on: 5 May 2005, 03:49 am »
I'll do it the easy way and listen. I had some Russian teflon caps to try. Dunno if they will matter much, but it's fun to try. Thanks Jim.
