Scanspeak/Vifa MTM speakers in excellent condition $775
0 Members and 1 Guest are viewing this topic. Read 1608 times.
apt_one
Top quality mtm speakers, sound quality , fit and finish are excellent. Conpetes very well compared with my other speakers costing 3 to 5k..
Prefer local pick up in Chantilly, VA. S50 discount for local pick up.
Components used-
Pair of MTM (Mid-Woofer / Tweeter /
Mid-Woofer) 2-Way Speakers
(4) Vifa PL18W009-04  7” Mid-Woofers
(2) Scan-Speak D2905/950000 1”
Textile Dome Tweeters
(2) Dayton .75 Cu Ft MTM Cherry
Semi-Gloss Speaker Cabinets (2.5” port)
Crossovers were built using high quality components and the LEAP ( loudspeaker enclosure application program.)
Cabinet Dimensions: 20” H x 8” W x
13” D (finished wt ~ 30 lbs each)
Condition
Excellent working condition/cosmetics
Assembled with
high-end parts in 2006, costing in excess of $2000+
Suitable for both transistorized as well as tube amplifiers, 8 to 250 watts per channel
“The Scan-speak D2905-950000 is similar to the
D2905/9300, but with non-resonant chamber. The optimized pole piece geometry
reduces flow resistance and the anti-resonator-plug in the rear chamber
eliminates turbulence. A light ferrofluid is used in the air gap to ensure
optimal linear mechanical behavior and minimal micro-dynamic non-linearity.
This tweeter has a smooth transparent sound and very low levels of distortion.
A perfect choice for any high end system.” …Madisound
“The Vifa PL woofers were designed without compromise and feature
a specially coated paper cone, Non Resonant Suspension Coupling (NRSC) system,
long linear excursion, and a vented pole piece.” …Parts Express
« Last Edit: 31 Dec 2023, 05:59 pm by apt_one »
