BDP-1 Freezing up after 10mins
0 Members and 1 Guest are viewing this topic. Read 1182 times.
TJ-Sully
« on: 30 Dec 2023, 01:35 pm »
I loved my BDP1 - and encouraged a good buddy of mine looking to upgrade his system to buy a used bdp1 and BDA2. He’s having issues with the bdp-1 - and hoping someone can help!   He’s got a call into Bryston - but they’re not open until next week.
Using the  BDP-1 as a Roon end point - it freezes up after about 10 minutes of use after a reboot.   trouble shooting so far:
1.  Updating the firmware
2.  Software reboot
3.  Resetting to factory
4.  Clearing the queue
5.  Shutting off the usb and other services
6.  Switching the Ethernet cables
7.  Connecting it to a separate standalone router with no other connections
  • The Demo is Everything!
    • http://www.bryston.com
Re: BDP-1 Freezing up after 10mins
« Reply #1 on: 30 Dec 2023, 02:23 pm »
Have your buddy contact Adam please - [email protected]
TJ-Sully
« Reply #2 on: 30 Dec 2023, 03:08 pm »
Will do.  Thanks James!
vonnie123
« Reply #3 on: 30 Dec 2023, 06:53 pm »
Bryston will get your friend fixed up.  I had to reflash the CF operating system card a couple of times back when i owned my two BDP-1s.  Not sure how they got corrupted, but they did.  Have BDP-2s now.  Been much less quirky than the earlier versions.
https://usermanual.wiki/Bryston/BDPManualManicMooseInstall.615412594.pdf
TJ-Sully
« Reply #4 on: 30 Dec 2023, 08:33 pm »
Thanks Vonnie…..we’ll have a look at this!
