BDP as Roon endpoint
0 Members and 1 Guest are viewing this topic. Read 750 times.
jobiwon
« on: 27 Dec 2023, 08:46 pm »
I primarily use my BDP Pi as a Roon endpoint these days.  What exactly happens internally when running the Pi as endpoint.  When you set the playback method to Roon it shuts down MPD correct?  Does it just use Roon libraries to render the stream from there?  What software/hardware is used?
vonnie123
Re: BDP as Roon endpoint
« Reply #1 on: 29 Dec 2023, 03:51 am »
MPD is turned off, and the BDP becomes a Roon Ready Renderer.  The Roon Library is utilized.
