BR-20 and Qobuz playlists
0 Members and 1 Guest are viewing this topic. Read 926 times.
alanford69
« on: 27 Dec 2023, 05:35 pm »
Hello, it happens that when I open one of my Qobuz playlists in MM and scroll the titles they are duplicated and the list change as I scroll up and down.
Did anyone experience this?
It is very annoying, hopefully will be fixed by the next software update?
  • The Demo is Everything!
    • http://www.bryston.com
Re: BR-20 and Qobuz playlists
« Reply #1 on: 27 Dec 2023, 06:19 pm »
Hi Alan
Are you creating the Playlist in MM or in Qobuz - should create the list in MM
james
alanford69
« Reply #2 on: 27 Dec 2023, 07:37 pm »
Hi James,
I am trying to access the playlists I previously created in Qobuz using the Qobuz app.
MM allows me to browse them and drill down to see the included tracks but messes up displaying duplicated titles.
