SOLD: NAD D3020V2 Integrated Amplifier- Free Shipping - price lowered
0 Members and 1 Guest are viewing this topic. Read 1385 times.
pstrisik
  • Holding pattern in Audio Nirvana in the PNW!
-----------------SOLD-----------------
Operationally excellent, cosmetically good (for a few surface scratches on the sides and small dent in remote).
Includes amplifier, remote, power cord, adapter for subwoofer (mini to RCA), documentation, original packaging.  Has optical, coax, rca (aux), Apt-X BT, MM phono, sub-out, pre-out, and 12v trigger in.
Double boxed (technically triple boxed) for shipping.  $399 plus $25 $379 with free shipping anywhere in contiguous US.  Paypal f&f preferred.
https://nadelectronics.com/product/d-3020v2-hybrid-digital-amplifier/
Audio Specs
    Rated Power at 8 ohms - 2 x 30 Watts
    IHF Dynamic Power 8 ohms - 2 x 60 Watts, 4 ohms - 2 x 100 Watts, 2 ohms - 2 x 150 Watts
    Signal/Noise Ratio (A-weighted, ref. 1 Watt):  ≥90dB
    Channel Separation 1kHz: ≥75dB, 10kHz: ≥65dB
    Channel Balance: 0 ±0.3dB
    Frequency Response (20Hz – 20kHz): 0dB to -0.3dB
    Total Harmonic Distortion: ≤0.005%
    Maximum input level:  5V
    IMD (SMPTE): 0.02%
    IMD (CCIF): 0.003%
MM Phono Input
    Phono Signal-to-Noise Ratio: >82 dB (200 ohms source, A-weighted, ref. 500 mV out)
                                                76 dB (MM cartridge source, IHF; A-weighted, ref. 500 mV out)
    Input sensitivity: 1.15 mV (ref. 500 mV out, Volume maximum)
    Maximum input signal at 1kHz: >90 mVrms (ref. 0.1 % THD)
    Frequency response: ±0.3 dB (20 Hz – 20 kHz)
General
    Standby Power: ≤0.5 Watts
    Supports bit rate/sample rate: up to 24/192 (via Digital Audio input)
    Unit Dimensions (W x H x D) Gross: 58 x 186 x 219mm / 2 5/16 x 7 3/8 x 8 5/8”
    Net Weight: 1.38kg (3.05lb)
    Shipping Weight: 2.1kg (4.6lb)
« Last Edit: 29 Feb 2024, 09:13 pm by pstrisik »
pstrisik
Re: FS: NAD D3020V2 Integrated Amplifier- Free Shipping
« Reply #1 on: 12 Feb 2024, 01:22 pm »
bump
pstrisik
Now $379 with free shipping.
