BP 25 preamp volume sensitivity
0 Members and 1 Guest are viewing this topic. Read 1584 times.
Vhond
« on: 11 Dec 2023, 10:44 am »
Situation as follows:
Metrum Onyx DAC connected using XLR to the BP25 preamp. BP25 connected using RCA to Class D Power amp.
When I use the remote for adjusting the volume I hardly have any margin between soft and loud.
Amplification of the signal is quickly too much. There should be more in between.
Anybody who can explain this? Maybe a solution for this problem?
jcn3
Re: BP 25 preamp volume sensitivity
« Reply #1 on: 11 Dec 2023, 04:17 pm »
my guess is that your dac is putting out more voltage than the bp-25 was designed to accept.  simple solution/quick fix is to reduce the output of your dac.
another potential option is the gain on your amp.  check and see if you can reduce the gain.
Vhond
« Reply #2 on: 12 Dec 2023, 12:04 pm »
Thx for your suggestions.
As far as I can see both are not just simply adjustable with (dip)switches....
clpetersen
« Reply #3 on: 12 Dec 2023, 01:30 pm »
On the RCA cables (pre-amp to amp) you can try some Harrison Labs in-line attenuators. I have used these in a similar situation. Can order direct thru Harrison Labs. I suggest the 12 dB versions, or order a variety. The 3 dB version is actually quite subtle.
jcn3
« Reply #4 on: 12 Dec 2023, 08:39 pm »
what is the class d amp that you're using?
Vhond
« Reply #5 on: 13 Dec 2023, 06:33 am »
a Mueta self oscillating (based on hysteresis) amp.
Vhond
« Reply #6 on: 13 Jan 2024, 02:33 pm »
I found this topic:
This is now my problem too: https://www.audiocircle.com/index.php?topic=111763.20
It's called bleeding.
I just ran into it when having new (higher sensitive) speakers.
On the power amp side I don't have a possibility to control the gain, so I don't know if another solution is available for me??
jcn3
« Reply #7 on: 13 Jan 2024, 03:13 pm »
Unfortunately, it sounds like you have component mismatches.  It appears the only solution is to get amplification (pre and/or amp) with less gain and/or less sensitive speakers.
Vhond
« Reply #8 on: 13 Jan 2024, 03:23 pm »
That would not be so fine...
