GR Neo 3 FRD & ZMA files
0 Members and 1 Guest are viewing this topic. Read 1201 times.
Moore66982
« on: 4 Dec 2023, 03:37 pm »
Is there somewhere I can download officially published FRD & ZMA files for the GR Neo 3?
Danny Richie
Re: GR Neo 3 FRD & ZMA files
« Reply #1 on: 4 Dec 2023, 07:11 pm »
We do not publish those types of files as using them for design work will often yield very poor results.
The drivers response is completely dictated by the application. How it is mounted, if it is mounted in a wave guide, how large the waveguide is, how large the surrounding baffle is, the edge diffraction, etc., all vary the response a great deal.
It is far better to design the crossover based on the application that it is being used in.
Heuserj
« Reply #2 on: 5 Dec 2023, 12:27 am »
Are the GR Neo3 the same size as the BG Neo 3. Would they fit in a baffle designed for the BG3 and are they open on the back?
Thank you.
Moore66982
« Reply #3 on: 5 Dec 2023, 12:33 am »
Thanks for the advice Danny…
Danny Richie
« Reply #4 on: 6 Dec 2023, 04:57 pm »
Thank you.
The frames are the same. The rest is different.
Heuserj
« Reply #5 on: 7 Dec 2023, 12:14 am »
Thank you very much.
