Newbie to the group
0 Members and 1 Guest are viewing this topic. Read 967 times.
McPege
Newbie to the group
« on: 2 Dec 2023, 10:07 pm »
I am an aufiophile of over 40 years. I also have a recording studio. I am passionate about the B&W 801 Nautilus being driven into two Classé Omega supplemented by two B&W ASW850 for acoustic balancing. (which serves as a mastering reference when we produce music). At heart, my passion as an audiophile is probably driven by my search of the truth in musical listening. So, in short, I'm an "oldie" newbie.  My main focus here is to search for high-end audio equipment for my own purposes (to collect or to use for myself). Warm regards to all in this community.
McPege
Re: Newbie to the group
« Reply #1 on: 2 Dec 2023, 10:27 pm »
To add as a second post, I am looking to repair input connection on the B&W ASW850 Subwoofer.  I heard it was a potential snag in this otherwise superb sub. Does anyone comme across how to repair the input connection?
McPege
« Reply #2 on: 2 Dec 2023, 10:30 pm »
B&W ASW850. Do any of you know of similar issues in other subs. One member says it's just a quick soldering at the input connection behind the sub.  Any of you have details?
McPege
« Reply #3 on: 2 Dec 2023, 10:33 pm »
Does this one make it a third posting. Just looking forward to interact with others. Any suggestions as to specific circles I should go with such a specific topic? Help?
« Reply #4 on: 2 Dec 2023, 11:08 pm »
Welcome tô AC :thumb:
Do you mean say connector?
« Reply #5 on: 3 Dec 2023, 12:17 am »
Please note some Circles of interest you may like>
The Fullrange Driver Circle:
https://www.audiocircle.com/index.php?board=128.0
The Open Baffle Circle:
https://www.audiocircle.com/index.php?board=90.0
The Tube Amps Circle>
https://www.audiocircle.com/index.php?board=144.0
« Reply #6 on: 3 Dec 2023, 12:18 am »
Today audiophiles can take vantage from inexpensive and transparent powerful Class D amps and recently with Lii Audio, take vantage from inexpensive big cones full range drivers, this will save a lot of money hence no crossover and no enclosure need.
This is a inexpensive DIY project from a AC member, it have only four(4) parts: Eminence Alpha15A + 4.7mH + Visaton B200 and a MDF baffle.
Other option are the Lii Audio F15 FR driver $399/pair, not each.
Here Decware OB with the Lii Audio F15 driver:
If one have a woodworker is possible try the Lii Audio F15($399/Pair, pair not each) 97dB/8Ω and benign impedance curve suited to OB or Bass Reflex box or the F18($540/pair), no Crossover, no Tweeter beaming, no Phase rotation, no driver sensitivity loss, no Harmonics loss, no Retail price.
http://www.glowinthedarkaudio.com/lii-audio-f18.html
If you want a bigger woofer there are 18'' and 21'' from Lii Audio:
https://www.lii-audio.com/product/w-18/
https://www.lii-audio.com/product/w21/
« Reply #7 on: 3 Dec 2023, 12:33 am »
If you mean say hi power amps I cant help, but if you like small amps take a look at this independent site(no advertisers).
http://www.glowinthedarkaudio.com/amps.html
« Reply #8 on: 3 Dec 2023, 09:02 am »
Greetings & Welcome to AC   :thumb:
Phil A
« Reply #9 on: 3 Dec 2023, 10:06 am »
Welcome!
