BDP-1 : unable to connect to BDP-1
0 Members and 1 Guest are viewing this topic. Read 1093 times.
Wim J
« on: 1 Dec 2023, 02:18 pm »
My 12 years old BDP-1 started behaving strange about 1 month ago. I had to reboot it several times before Roon could see it. This behaveiour got worse and worse and now I can't even get a response from its IP adress ( (it's fixed DHCP)  I ruled out the network cable and switch to which it is connected.
The display reads :
Bryston BDP-1
N
I can not use the arrows-keys  and the only button that seems to work is power on/off.
I checked the internal lithium battery which is at 3,07 Volts, so that´s ok. Also the 12V an 5V power suplly voltages are ok and stable
What does the N in the display mean?
is the CF card bad? where do I get an image to flash a new CF card?
In my opinion the network input on the motherboard is not behaving properly or faulty.
But if you have any ideas, I sure would like to hear about them.
hawkeye99
Re: BDP-1 : unable to connect to BDP-1
« Reply #1 on: 1 Dec 2023, 07:43 pm »
Have you tried clearing your cache?
gil99
« Reply #2 on: 1 Dec 2023, 09:27 pm »
I have the same issue With my bdp-1, disconnecting the power cord for ten minutes then connecting it back & power on the bdp my displays shows the same as yours with the « N », but my BDP is working. Asking myself also what the N is for. Have to disconnect the power cord every 2-3 weeks, still working for now.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #3 on: 1 Dec 2023, 09:45 pm »
Hi Wim - email Adam on this please - [email protected]
Wim J
« Reply #4 on: 2 Dec 2023, 08:47 am »
I will send out an email to Adam. Thank you.
