New, from So Cal
0 Members and 1 Guest are viewing this topic. Read 895 times.
tewtom
New, from So Cal
« on: 24 Nov 2023, 05:39 pm »
Happy Thanksgiving to all!  I live in San Dimas CA, have the following set up-
Nakamichi CA5 preamp
Sony CD player  :oops:
Mcintosh MR500 tuner
Thorens TD145 with a bunch of mods I did myself
Denon 103R with Denon 320 SUT
Backup Ortofon Black
McIntosh C7100 amplifier
McIntosh ML1C speakers
McIntosh MQ101 equalizer
Speakers are updated with high frequency driver modifications Roger Russell provided me
Looking to replace the Nakamichi preamp with maybe the FET valve CFR with onboard phono.
Anyone with great experience with the preamp with phono, would love to hear your experience/advice!
That's my story folks kinda boring.  Thanks!
Re: New, from So Cal
« Reply #1 on: 24 Nov 2023, 11:16 pm »
Welcome to AC  :thumb:
Do you use the equalizer?
« Last Edit: 25 Nov 2023, 04:31 am by FullRangeMan »
Phil A
« Reply #2 on: 25 Nov 2023, 03:12 am »
Welcome!
« Reply #3 on: 25 Nov 2023, 01:03 pm »
Welcome!
After 50+ years at this my system consists of:
- Buchardt A500SE active monitors with dual 6.5 inch Purifi mid/woofers, (4) 150 watt mono-blocks, (4) DAC's, multiple "Master Tunings", rated 25-40,000 Hz +/- 1.5 dB
- Primare SC15 Mk2 (still waiting to be delivered) wireless pre-amp, streamer, room EQ, WISA speaker connection.
- MacBook Air for wireless connection for Tidal
tewtom
« Reply #4 on: 25 Nov 2023, 07:42 pm »
Hi fullrangeman, yes, I use the MQ101.  It works great!  And I just recently had it checked out by Mike Zucarro in San Diego, all up to spec.  Thanks!
« Reply #5 on: 25 Nov 2023, 09:19 pm »
Greetings & Welcome to AC   :thumb:  A totally excellent setup.  8)
tewtom
« Reply #6 on: 25 Nov 2023, 10:22 pm »
 :thumb:
