Bryston 6B SST Grab Handle Removal
0 Members and 1 Guest are viewing this topic. Read 862 times.
blowenthal
« on: 24 Nov 2023, 02:21 pm »
Just bought a rack mounted Bryston 6B SST, but have a cabinet to house it in. Are the front grab handles removable? Also, anyone know of a faceplate for the cabinet version that is available for purchase?
mv038856
Re: Bryston 6B SST Grab Handle Removal
« Reply #1 on: 1 Dec 2023, 06:31 pm »
The handles usually can be removed.
With my 6B SSTs, they have visible screws in the handle.
So you can take them off, but you need shorter screws then to hold the front panel parts together. I also converted a silver 17“ 6B SST w/o handles into a black 19“ unit w/ handles.
Contact Bryston with the serial of your unit and they will be able to tell you which options you have.
P.S. The 6B SST still is my favorite Bryston amp. It is an engineering marvel! I am using three of them in my home theater.
