Remote Control for Tempest Preamp
0 Members and 1 Guest are viewing this topic. Read 3582 times.
88man
« on: 18 Nov 2023, 12:47 pm »
Greetings! My Tempest Preamp volume remote doesn’t work. Any good recommendations for a simple, replacement remote? What code works on Tempest?
I’ve had the Stratos Dual Mono and Tempest for 17 years, and it has been working well after the initial Extreme upgrade.
I emailed Klaus to buy another remote, but never got a response. The LED behind the Tempest logo is out too now. Even though, technically, it’s still under warranty, I can replace it myself, as I do with the rebiasing. But remotes are tricky, so I thought I’d ask the group.
Thanks.
klaus@odyssey
Re: Remote Control for Tempest Preamp
« Reply #1 on: 21 Nov 2023, 10:58 am »
Well,  there's no learning ID  code...you'll have to have a remote where you can program via signal...or just call me and I'll send you another one
88man
« Reply #2 on: 24 Nov 2023, 05:01 am »
Thanks, Klaus. I’ll call Monday.
