GR Research power cable
0 Members and 1 Guest are viewing this topic. Read 2504 times.
DLStryker
« on: 12 Nov 2023, 03:52 am »
Is a GR Research power cable to my power conditioner and then a GR Research power cable from my DAC to the power conditioner too much filtering?  Both OK?  Only use one?
DonS
Re: GR Research power cable
« Reply #1 on: 12 Nov 2023, 04:25 am »
That's what I do.
Danny Richie
    • http://www.gr-research.com
« Reply #2 on: 13 Nov 2023, 01:54 am »
Listen and find out.
Hobbsmeerkat
« Reply #3 on: 13 Nov 2023, 02:52 pm »
To my knowledge, the only time a customer has had issues with over-filtering was when using the B24 with a PS-Audio Regenerator where it supposedly was knocking out a lot of the upper treble & harmonics frequencies.
