Crates sized for albums are at Target
0 Members and 1 Guest are viewing this topic. Read 2112 times.
sanlanman
« on: 10 Nov 2023, 07:06 pm »
Heads Up, Target is selling a wood crate that is ideal for LP albums, (you know - vinyls).
Its an unfinished wood crate made from Paulownia Wood. Outside dimensions are 14" L x 13" W x 11" H with 3/8" thick walls. These don't look like plywood. Surface texture is a bit course so they will need to be sanded with some 100 or 120 grit sandpaper before finishing. I bought 3 and stained and sealed them, and, I liked them so well that I went back and got 2 more. The list price is $20.00 ea, but at the moment are on sale for $16.00 each. Considering what other dedicated wood record crates cost, they are a steal. They are in stock at some stores. Here's the link:
https://www.target.com/p/large-decorative-light-wood-crate-natural-brightroom-8482/-/A-83378258#lnk=sametab
They have felt pads on the bottom but I removed them for finishing and replaced them with small silicone bumper pads.
Also, If you want a prefinished crate option, here's one for you. Its a dark finished wood file crate. You will have to cut out the 2 hanging file folder rods, then they will be perfect. They hold about 1/3 less albums than the unfinished one above. Cut the rods in the middle and the pieces come right out, then you are good to go.
https://www.target.com/p/wood-file-holder-brown-threshold-8482/-/A-15023557#lnk=sametab
I am using a couple of these in another location.
HTH
h2oyo
Re: Crates sized for albums are at Target
« Reply #1 on: 10 Nov 2023, 08:12 pm »
Good deal thanks.
