Cambridge Ensemble II
0 Members and 1 Guest are viewing this topic. Read 1857 times.
« on: 7 Nov 2023, 10:59 pm »
I too had the opportunity to directly A-B the Bose sub-sat system with the Cambridge Ensemble II. The Bose was shrill, bright, and hard. The Cambridge, aside from a bit of tubbiness in the bass that was completely cured by a little Plasticlay, was far more musical and listenable.
dB - how bad is the Cambridge?
« Last Edit: 8 Nov 2023, 12:46 am by mix4fix »
Re: Cambridge Ensemble II
« Reply #1 on: 8 Nov 2023, 06:27 pm »
If anybody have it or have had it, I like to know your thoughts on it.
charmerci
« Reply #2 on: 9 Nov 2023, 04:22 am »
I think I had one in 2012. It's okay. If you found one in a thrift shop for $20. It's fine for the garage or background music. Better than Bose....but that's not saying much I guess.
Let's just say that I was impressed with it enough to keep trying other budget speakers.
vrao81
« Reply #3 on: 9 Nov 2023, 06:14 pm »
Cambridge Soundworks has been out of business for a couple years now. I bet there are much better budget sub/sat systems from Edifier and the like.
