Why no wing on x-Statik?
0 Members and 1 Guest are viewing this topic. Read 955 times.
tomlinmgt
« on: 5 Nov 2023, 06:56 pm »
NX-Otica/-Treme have the wing at the MTM section....why not x-Statik?
S Clark
Re: Why no wing on x-Statik?
« Reply #1 on: 5 Nov 2023, 08:13 pm »
Because the X-Static has a sealed set of mid woofers to handle bass... extending into the 40s or 50's.  The others are designed to hand off to subs reaching up to just below 200Hz.  The wing is for bass augmentation to get it to reach down when open baffle.
If I understand it correctly....
Danny Richie
« Reply #2 on: 6 Nov 2023, 09:56 pm »
The crossover is having to adjust for the smaller flat baffle with no side wings on the X-Statik.
In the NX models the baffle corrects for the front to back wave interaction and balances out the output without the need for crossover correction.
tomlinmgt
« Reply #3 on: 8 Nov 2023, 06:13 pm »
Got it. Thank you.
