What A Long Strange Trip
0 Members and 1 Guest are viewing this topic. Read 1553 times.
Toys4Boys
« on: 29 Oct 2023, 02:34 pm »
I've been selling audio for over 40 years fueled by my first and most enduring love, music. Have been collecting records for over 50 years and played with a lot of gear for almost as long. Recently I was bitten by the DIY bug, in the process of building an Eros 2 phono pre, waiting for an ANK DAC1.1, getting ready to pull the trigger on a TU-8900. I've been intrigued by SET amps for a few decades but never played with any, the closest that I think I came was a pair of Jadis JA80s, glorious on some music a bit lacking on others and the price  :duh:
I have also been researching speakers to go with an SET and the XStatics seem to check off almost all the boxes, wish that I had the space and budget for the NX-Otica!
One box that they don't quite check off is the FlatPak aesthetics. Once upon a time I was married and had a house where I set up a nice wood shop, so now not much space to do woodwork. A poster had a link to veneersupplies.com and while I could probably do something like that for the baffle I'm wondering if there is a clever way to deal with the corner/edges?
planet10
  • Frugal-phile (tm)
    • planet10-hifi
Re: What A Long Strange Trip
« Reply #1 on: 29 Oct 2023, 05:19 pm »
The TU-8900, especially with 2A3, seems to be a special amplifier.
A SET with typically highish output impedance really wants to see a loudspeaker with a fairly flkat impedance. What does teh impedance of the xstatic look like/
dave
Toys4Boys
« Reply #2 on: 29 Oct 2023, 05:35 pm »
Here is a link https://gr-research.com/product/x-statik-kit/ to the product page, scroll down and there are graphs of freq. response and impedance.
mlundy57
« Reply #3 on: 29 Oct 2023, 05:52 pm »
You will want to put 3/8" or larger roundovers on at least the vertical the edges of the baffles. The rest of the edges can be roundovers or chamfers whichever you prefer. I don't know if other types of profiles would compromise the integrity of the joints or not.
Toys4Boys
« Reply #4 on: 29 Oct 2023, 05:57 pm »
Wouldn't the top edge become a problem if I use roundovers?
Toys4Boys
« Reply #5 on: 29 Oct 2023, 06:08 pm »
I probably should have been more specific, I assume that you wouldn't be able to successfully fold against the grain to cover the top edge?
mlundy57
« Reply #6 on: 29 Oct 2023, 07:39 pm »
Correct. If you are going to veneer the baffle, only use roundovers on the vertical edges.
Toys4Boys
« Reply #7 on: 29 Oct 2023, 07:59 pm »
Okay, that would certainly eliminate the majority of edge work. I'm starting to think I will screw the front baffle to leave myself options.
planet10
  • Frugal-phile (tm)
    • planet10-hifi
« Reply #8 on: 30 Oct 2023, 06:30 pm »
Here is a link
Thanx.
With a SET the bottom half of the midrange is going to be affected by the impedance interaction. How it deals with the bump at teh bottom is a bit more complicated.
X-Stic is also an OB/box hybrid. Hard to get right.
Why? We have veneered many boxes with chamfers or none.
dave
Toys4Boys
« Reply #9 on: 30 Oct 2023, 07:29 pm »
Isn't the bump at the bottom somewhat innocuous as it is where the bass rolls off? In the mid range isn't that a result of the xover and somewhat common in multi-way speakers?
Aren't all designs  :wink: I am intrigued by 300B amplifiers and would like to put together a somewhat affordable system around 1. From what I can find there are few options that fit the bill, biggest problem is I need a narrow front baffle.
He was replying to my wondering if there were any tricks to simplify the edges. Living in a condo makes it difficult to do some things.
Mark
