If you could design your own speaker....
0 Members and 1 Guest are viewing this topic. Read 4589 times.
jmimac351
Re: If you could design your own speaker....
« Reply #40 on: 28 Oct 2023, 08:19 pm »
Ok Danny/Hobbs, let’s start off easy. How about a new Super Mini using the Radian LM10?
So, how many Radian LM10 x $329 would that be?
(Asking for my wife)  :thumb:
Hobbsmeerkat
« Reply #41 on: 28 Oct 2023, 08:27 pm »
Super mini used 1 Neo10 per speaker. So it would need 2 total.
jmimac351
« Reply #42 on: 28 Oct 2023, 08:40 pm »
Got it.
mkrawcz
« Reply #43 on: 28 Oct 2023, 08:49 pm »
The drawback is there is likely to be a hole in the response to fill between the minis and the servo subs.
« Reply #44 on: 28 Oct 2023, 09:06 pm »
Nope, the integration is seamless.  The midpanel on the Super Mini plays as low as the ones in my Super 7, just not as loud.  Just turn the crossover point on the subs 'almost' all the way up and it matches pretty much perfectly with where the midpanel drops off.
mkrawcz
« Reply #45 on: 28 Oct 2023, 09:13 pm »
I would imagine there are a lot of people here that would buy these the day they became in stock at GR research.
jmimac351
« Reply #46 on: 28 Oct 2023, 09:15 pm »
So, after "DaHobbs" finish up my NX-Otica Triple Eight (made up name) speaker, I can have a pair of these sitting next to them on the entertainment center and use the servo subs in the Otica speakers for TV duty as well... dual duty on the Otica 8" drivers.
« Reply #47 on: 28 Oct 2023, 09:18 pm »
Yes, you'd basically get similar (or better) performance as the $25k PS Audio speaker.  I say 'similar or better' because the PS Audio speaker is a box and some people will like that more, but most won't, IME.
https://www.psaudio.com/products/fr30-loudspeaker
I will say the fit and finish of that speaker is very nice.
mkrawcz
« Reply #48 on: 28 Oct 2023, 09:29 pm »
Yea, the FR30 is not going to produce a soundstage or image anywhere near as good as the Super Minis.
