SOLD Willsenton R8 Integrated Amp
0 Members and 1 Guest are viewing this topic. Read 672 times.
Charles Xavier
« on: 18 Oct 2023, 01:44 pm »
Clearing out some gear.
Willsenton R8 comes with stock tubes and 2 quads of El34 tubes Psvane and Electro Harmonix as well a
s stock KT88 tubes and stock preamp tubes. Remote, power cord, and original box and packing. Excellent condition. Local pickup preferred but will ship at buyer's expense. PP family friends or cash or Zelle on local pickup.
1100.00 PP family and friends or cash or Zelle local pickup.
Features
Pure hand-made, the whole machine is welded with scaffolding.
Use a square power transformer specially developed for this machine.
The output transformer uses two high quality wideband EI output transformers.
The voltage amplification and boost stage uses a 6SN7 for power supply filtering.
The voltage amplification stage and the push stage use two pairs of 6SL7 and 6SN7 tubes, respectively.
The rear stage uses four KT88/6550/EL34 tubes for class AB single-ended power amplification.
Triode and ultra-linear selection are available.
External independent BIAS-ADJ current display header.
External EL34/KT88 tube selection function, easy to replace different types of tubes, adding endless fun.
Infrared full-featured remote control.
Use thick silver plated signal leads.
With pure post-level function, it can be connected to independent preamplifier signal input.
Power on mute delay function (about 30 seconds).
Select Japanese ALPS high-end motor potentiometer.
Easy-to-install plug-in tube shield.
Product parameters:
Frequency effect: 10Hz 40kHz (+/-0.5db)
Total harmonic distortion: 1% (1kHz)
Signal to noise ratio: 91dB
Input sensitivity: 380mv (when Integrated amp input) 820mv (when pure power amp input)
Input impedance: 100KΩ
Output impedance: 4Ω, 8Ω
Power supply voltage: 230V ± 5% (50Hz) ~ 115V ± 5% (50Hz)
Machine volume (400*200*390) (W*H*D) mm
Use vacuum tube: 6SN7*3.6SL7*2.KT88*4/6550EH*4/EL34*4
Power consumption: 310W
Net weight: 26kg -90%
Rated output power:
25W+25W (RMS triode working state)
45W+45W (RMS ultra linear working state) (KT88)
40W+40W (RMS ultra linear working state) (EL34)
« Last Edit: 21 Oct 2023, 09:56 pm by Charles Xavier »
Charles Xavier
Re: SOLD Willsenton R8 Integrated Amp
« Reply #1 on: 21 Oct 2023, 09:56 pm »
SOLD
