Older BP-25 preamp with BR 4 remote
0 Members and 1 Guest are viewing this topic. Read 1316 times.
sfraser
« on: 16 Oct 2023, 10:46 pm »
James, I just purchased a br4 remote, to use with my BDA3  DAC . I was hoping it would work with BP-25 preamp as well so I could consolidate , but no such luck. I have tried programming it with th "721" code listed on the data sheet . I have also tried a factory reset and then the 721 code. My IRTx1 remote which came with the preamp works fine . The data sheet says 721 should be the code for BP25/26 PRE's. My suspicion is my BP25 might be an older vintage perhaps?the br4 does control the DAC just fine btw, so it looks like a compatibility issue, or another code is required .
Scott
  • The Demo is Everything!
    • http://www.bryston.com
Re: Older BP-25 preamp with BR 4 remote
« Reply #1 on: 17 Oct 2023, 12:59 am »
Email Adam and se if he can help - [email protected]
sfraser
« Reply #2 on: 17 Oct 2023, 01:09 am »
Will do , thanks.
