SOLD: Black Ice Audio Glass FX 10 Integrated Tube Amplifier
0 Members and 1 Guest are viewing this topic. Read 751 times.
MT POCKETS
Original owner purchased this past August moving up to the FX 11 hence the sale. Includes remote and stock tubes EH EL84 and Sovtek 12ax7wa. Price includes shipping to lower 48. PayPal add 3% or FF.
Will only ship to US address. $495.00
Bandwidth: 14Hz to 50KHz + 3dB; 0dB = 10 W 1KHz, 8 ohms
Distortion THD: Less than 1% at 10 W output, 39Hz to 10KHz, 8 ohms
Circuit Type: Ultra Linear, Class AB1
Inputs:  2x RCA  and 1x 3.5mm Line In
Input Impedance: 100Kohms
Input Sensitivity: Max. 670 mV for 10 watt output at 1KHz
Output Impedance: 4 ohms and 8 ohms
Negative Feedback: Less than 3 dB
Noise and Hum: 81 dB below rated output from 10Hz to 200Khz
Tube Complement: 4 x EL84 power output; 2 x 12AX7A/ECC83
Power Requirements: 110V-120 VAC 60Hz 6 watts-standby, 350 watts maximum (220 VAC 50Hz option)
Dimensions: 8 inches wide by 7 inches deep by 7 inches high.
Weight: 12 pounds net, approximately 16 pounds packaged.
Bias Settings: Self-biasing
Fuse: 110 - 120 VAC, 2 Amp Slow Blow; 200 - 240 VAC, 1 Amp Slow Blow, Size 5mm X 20mm
« Last Edit: 17 Oct 2023, 10:53 am by MT POCKETS »
