SOLD [FS] Empirical Design ED 213 Speaker Cables - 16 foot set -Banana to Banana
0 Members and 1 Guest are viewing this topic. Read 1124 times.
Freejazz
SOLD
[FS] 16 foot set Empirical Design ED 213 Speaker Cable  - Bananas to Bananas
Rare 16 foot set
Banana to Banana
Very Good condition with light wear to bananas and two spots of white paint on outer jacket
These are simply wonderful and replaced much more expensive speaker cables in my final system.
Original price $1540
Sell for $390 + actual shipping/insurance to buyer’s location
Paypal, Venmo, zelle, cashier’s check or cash
Thanks, Scott in Pittsburgh, PA 15207
Manufacturer’s Description
Speaker cables present a complex challenge: they must have sufficient cross-sectional area to deliver high current peaks from the amplifier with minimal loss. However, merely increasing either wire thickness or the number of strands in a wire bundle will introduce a host of distortion-generating artifacts – most significantly, phase shift due to excessive skin depth. In order to solve this problem in the most elegant manner possible, Empirical Design has developed an innovative conductor for the ED 213 Speaker Cable.
High-purity copper strands are woven into a single-layer braid surrounding a Teflon* core, forming a "virtual cylinder" with an effective cross-sectional area equivalent to a 13 gauge wire. The resulting tubular conductor is less than 1 millimeter thick, thereby eliminating phase shift across the entire audio frequency range, but still of sufficient size to enable full power transfer from the amplifier to the loudspeaker. The Teflon* insulated positive and negative leads are bonded together in a parallel geometry, preventing relative motion in order to stabilize cable reactance.
A proprietary labor-intensive termination process preserves the tubular conductor geometry all the way through the connectors, eliminating the usual "weak link" at the point of termination; there are no loose wire strands to oxidize or break with long-term usage. ED 213 will continue to perform ideally year after year, coupling your amplifier to your loudspeakers with breathtaking clarity, precision, and responsiveness.
Symmetrical bonded parallel conductor geometry
Pure Copper braided tubular conductors
Teflon* core and jacket
Premium gold-plated connectors
Environmentally sealed terminations
Abrasion-resistant protective sleeve
« Last Edit: 14 Nov 2023, 05:04 am by Freejazz »
Hackienet
Hi Scott, I’m interested in the Empirical Design speaker cables.  I live in MD. Would you be willing to go $350?  Thank you very much. Gary.
Freejazz
Hi Gary,
Just sent you a pm.
Scott
