Tidal
0 Members and 1 Guest are viewing this topic. Read 1706 times.
gil99
Tidal
« on: 10 Oct 2023, 06:38 pm »
Hi all,
I have a bdp-1 and cannot have Tidal working. I have no problem streaming with Qobuz, everything is working fine.  Tidal has work for a while but now when I login to Tidal, choosing an album it shows in the play queue but when I press play it shows an error. Is there a way to have Tidal to work.  Thank you.
Gilles
jobiwon
Re: Tidal
« Reply #1 on: 10 Oct 2023, 07:39 pm »
Maybe disconnect from Tidal in MM.   Clear out all the config settings for Tidal.  Then bounce MM.  Then reconfigure if for Tidal service.
gil99
Re: Tidal
« Reply #2 on: 10 Oct 2023, 08:11 pm »
Thank for your help,
How and where to log out from tidal.
gil99
Re: Tidal
« Reply #3 on: 10 Oct 2023, 09:33 pm »
In media player settings, tidal it shows not log in, but it does not show the option to enter the username & password. But un the default View it shows that I am log in as with my email. Any idea what I'm doing wrong. Thanks
jobiwon
Re: Tidal
« Reply #4 on: 12 Oct 2023, 10:35 pm »
Under media player settings I selected my music service (qobuz) and I see my login information (username password etc).  I would just go to your service and clear out the login information and hit save>. Also if I scroll down in that window I see a logout button.
