0 Members and 1 Guest are viewing this topic. Read 1556 times.
NoahH,Do you have the original larger Dodd Preamp or the variable gain version?The earlier ones used the 7308 like Scott indicated. The newer variable gain version uses 6h30 style larger tubes. For those, the OTK stamped ones are very good. Those also apply to the Dodd Buffer.
I've tried dozens over the years, and they are all different. I think I've had Valvo 7308 in longer than any others. I also liked Lorenz, and Seimens. If you're looking for warm, try Mullards.
