Industry Circles
Spatial Audio
Spatial Audio
herbies gliders for m5
0 Members and 1 Guest are viewing this topic. Read 5194 times.
rockymystic
26 Sep 2023, 05:29 pm »
Hello,
I own sapphire M5's and i m interested in adding Herbies threaded stud gliders on these M5. Does anyone know what is the thread size that i should choose from? Or is there any way to measure the correct size properly?
Mr. Big
Re: herbies gliders for m5
26 Sep 2023, 09:17 pm »
M6 is the size. I use them on my Sapphires M3s at one time. You can also call Spatial to check.
rockymystic
Reply #2 on:
27 Sep 2023, 05:20 pm »
I did call them, the new owners do not have an answer. so relying on our forum members
geerock
Reply #3 on:
27 Sep 2023, 05:37 pm »
I use the ones that don't attach.
Charles Xavier
Reply #4 on:
27 Sep 2023, 09:19 pm »
They are m6
James Edward
Reply #5 on:
28 Sep 2023, 01:02 am »
Go to a hardware store- get an m6 screw and a 1/4” one too. One of those will be correct- my M3 Turbos use 1/4”, though the newer models probably went metric. It shouldn’t cost more than 2 bucks, and you’ll know for sure.
Industry Circles
Spatial Audio
Spatial Audio
