SOLD- Diamond 3 Power Cable [C15 IEC] 5 ft $275.00
0 Members and 1 Guest are viewing this topic. Read 1234 times.
undertow
« on: 23 Sep 2023, 02:44 pm »
SOLD-
$275.00
48 State shipping included at asking price.
PayPal F/F payment accepted.
Will ship with original silk lined box from Italy.
It is in excellent shape. As good as a used power cable gets anyway, it has some marks on the silver prongs from being plugged into an outlet that can be polished out, but it’s a power cord so this is to be expected.
https://www.hidiamond.eu/eng/en/38-products/199-cavo-di-alimentazione-diamond-3
Cable with proprietary technology, 4VRC copper cooking for four times in order to obtain a reduction in values of inductance, capacitance and resistance mixed with graphite. Graphite in this solution allows to block the noise generated inside of the cable from the passage of an electrical signal (which is nothing the musical signal) to bring out a perfect signal without any introduction of noise that would spoil the final result.
Connectors with contacts in plating silver to ensure maximum energy transfer. PVC insulation. Double-shielded copper braid copper with graphite to eliminate any interference which allow a better signal transmission without loss. Technology twisted within the cable to get a great tonal balance. All these innovations bring to have a result that this cable has a huge dynamic impact, a yield in the low-pitched range hot and present detailed and never swell, the exceptional focus, wide soundstage outlined in all its extended size, deeply divided and open, both in height, width and depth.
Disarming conflict resolution speed during the attack transients, and fast release, with a propensity for descent below notable, crystal clear but never aggressive, more black around the orchestral plan guaranteeing a record-breaking three-dimensionality. Simply the point of arrival. A cable that is present but does not feel. Shown in all facilities at both solid-state valves of any value.
Technical characteristics: External jacket mm. 140; Number of Cond. 4 x 4,0mm; Cond. Graphite/Copper (4VRC); Capacity max. C1 130Pf/C2 255 Pf with schield.; Inductance : 0,75 u/M ; Conductor Resistance:4,95 OHM/km.
« Last Edit: 6 Oct 2023, 02:25 pm by undertow »
undertow
Re: HiDiamond Diamond 3 Power Cable [C15 IEC] 5 ft
« Reply #1 on: 27 Sep 2023, 08:13 pm »
SOLD
« Last Edit: 8 Oct 2023, 06:19 pm by undertow »
undertow
« Reply #2 on: 2 Oct 2023, 12:26 am »
SOLD
