BDP-pi and Qobuz
0 Members and 1 Guest are viewing this topic. Read 1135 times.
Calypte
BDP-pi and Qobuz
« on: 7 Sep 2023, 01:30 am »
The staff at Bryston helped with my USB output problem (hi-res files not working properly).  An update of the firmware image to the internal Micro SD card did the trick.
HOWEVER -- Now I can't get Qobuz to work.  It tries to play a file, and it even shows the cover art in MM.  Then it just stops and blanks out the cover art.  I'm thinking I have a wrong setting in Manic Moose.
What flags do I need to set in Manic Moose to get Qobuz to play properly?
Calypte
Re: BDP-pi and Qobuz
« Reply #1 on: 7 Sep 2023, 02:39 am »
Solved!  Within MM, I needed to go to "settings," where I had to set a bit depth for Qobuz.
