0 Members and 1 Guest are viewing this topic. Read 1817 times.
Welcome! Thanks ! My budget depends on the offer, i guess i can go up to 7k ish ?What's your budget?
Do you mean speaker with xovers? If só I would suggest Klipsch RF7 new or used with a small tube amp, EL34 SET 6watts. Avoid use Solid-State amps with horn speakers.If you want use this occasion to get rid of the boxed 2D soundstage speaker you may like this simple DIY project from a AC member: All parts are only four(4), Eminence Alpha15A + 4.7mH + Visaton B200 and a MDF baffle.
I willnot going comment on commercial speakers with xovers.Maybe you found some interesting info on this site on OBs>http://www.glowinthedarkaudio.com/speakers.html
