Rank the Top GR Research Speakers
Denton J
Re: Rank the Top GR Research Speakers
« Reply #80 on: 8 Sep 2023, 04:01 pm »
I'm waiting for something like a wmtmw or mtm design specifically designed to pair with doubles or triples but small enough to place on top of the subs.  Yes, I realize I'm asking a lot.
mlundy57
« Reply #81 on: 8 Sep 2023, 07:01 pm »
That's basically the Wedgie
On top of triple 8" OB subs in a wedge base
On top of Dual 12" OB subs in a wedge base
On top of triple 8" OB subs in H-Frame
If you use larger drivers for the woofer and midrange like in the NX-Otica, the tweeter would be way too high when placed on top of dual OB H-frames, let alone triples. Even the MTM section of the NX-Otica puts the tweeter above ear height when placed on top of dual H-Frames. Adding another large woofer under the bottom NQ driver would raise the tweeter another 7" above ear height.
Denton J
« Reply #82 on: 8 Sep 2023, 11:20 pm »
There are too many options Mike!
« Reply #83 on: 8 Sep 2023, 11:55 pm »
I doubt that GR will ever build a WMTMW tower design simply because they are selling these as kits and that gets into the 'somewhat too difficult' area for most people.
BrandonB
« Reply #84 on: 10 Sep 2023, 12:06 am »
I have been looking for the perfect speakers to go into my area.  I think I'm going with the Otica's or the new 8 in Otica's if I can wait that long.  I am not very handy so I have been hoping and trying  to catch a pair on the used market but I have come to the conclusion that the NX-Otica must be the best speaker because you hardly ever see them for sale. I have seen NX-Studios, LS6's LS9's but not the Otiica's.
« Reply #85 on: 10 Sep 2023, 12:23 am »
I think you are right, the Otica is a pretty special speaker.  I never thought I'd like another speaker as much as I like my Super 7's, but the Oticas are right up there.  They are different though.  The 7's are more like a Porsche (nimble but powerful) while the Oticas are more like Corvettes (powerful and blazing fast).
ebag4
« Reply #86 on: 10 Sep 2023, 04:29 am »
The MTM section of the Oticas sound pretty great on top of a pair of servos in H frame.  I was at Axpona this year and heard very few speakers that sounded as good, of course they aren’t set up optimally at a show but the Oticas sound “right” to my ears, YMMV.  This is my pair.
Best of luck with your search,
Ed
Denton J
« Reply #87 on: 11 Sep 2023, 01:17 am »
Ed
I like how you made the top fit on the below servo subs.
ebag4
« Reply #88 on: 11 Sep 2023, 01:34 am »
Thanks, that section also houses the crossover.
FWIW, I increased the H frame depth 1.5” total (3/4” each bay) to match the MTM depth.  Technically this reduces the upper frequencies the sub can reach but they easily reach the MTMs lower frequencies and present a seamless integration .
Best,
Ed
« Last Edit: 11 Sep 2023, 03:08 am by ebag4 »
jmimac351
« Reply #89 on: 12 Sep 2023, 03:08 pm »
« Last Edit: 5 Dec 2025, 06:17 pm by jmimac351 »
Hobbsmeerkat
« Reply #90 on: 12 Sep 2023, 03:23 pm »
@hobbsmeerkat... since it's kinda Bigly... let's go ahead replace the NQ drivers with a pair of M-165/16, make it a floorstander with shared airspace for the woofers via the cavity behind the "V" for the Neo 3 tweeter. Let's make it ~90db efficient, play to ~35Hz, and you don't need stands!
That would be about the only plausible option since you're basically making an X-MTM but with the NX Tweeter and waveguide.
jmimac351
« Reply #91 on: 14 Sep 2023, 12:50 am »
« Last Edit: 5 Dec 2025, 06:16 pm by jmimac351 »
nlitworld
« Reply #92 on: 14 Sep 2023, 02:08 am »
2) Best speaker for close to the front wall and I CAN have a sub (and maybe I have a High Pass filter)
2) X-CS Bravo - 90db, Left / Right 2 channel, paired with a sub. Sealed.  Close to wall OK.  Could the midrange be even better, faster, via smaller drivers than the Encore?  Look at the decay plot on this speaker.  It's badazz.  Hmmm.
Is the Neo tweeter worth going thru that trouble?... I can't hear it to find out.
Yeah, I can't argue the X-CS is a great speaker, but i will say the NX-Studios have the chameleon ability to play any location and do it even better. Full range or high-pass, SS or tubes, it doesn't matter. Technically in my small room, it doesn't even need a sub as my -3db is about 40hz. I do run 2 svs subs just to even out the room, but I often forget to turn them on. But the icing on the cake is that Neo3 tweeter is so damn good. When you can have a 12x10 listening room that still gives full, and I do mean FULL 3D representation of the music, that's saying something. X-CS is really good, NX-Studios are just that next step further. If and when you do get a chance to hear it, oooh man.  :wtf:
But yes, I absolutely agree in your notion of matching speaker to surroundings and equipment. I could only imagine the horror of NX-tremes in my room pulled 3ft out from the wall. That would be comical, and likely sound like 💩.  Know your limitations and expectations I guess.
BrandonB
« Reply #93 on: 14 Sep 2023, 02:42 am »
This "Rank The Top..." notion may be putting the cart before the horse.  For instance, the NX-Treme and Otica speakers are bad speakers... IN MY ROOM.
Everyone reading thru this site / thread likes playing with speakers.  The problem is, the speakers you WANT may not the ones you NEED - no matter how you try to rationalize otherwise.  A better way of "Ranking" might be according to Room / Placement / Overall strategies for achieving performance.
For Instance...
1) Best speaker for close to the front wall and I CAN'T have a sub.
3) Best speaker in "Free Space", but I still cannot have a sub - "Full Range"
4) Best speaker in Free Space, but I can have a sub.
5) Best Speaker to do either close to the wall or in Free Space... without a sub.
6) Best Speaker to use with lower powered amps.
7) Best Speaker that can Hit, Run, Hit for Power... and Pitch... i.e., Pound for Pound... the "MVP Speaker".
The answer(s) to those questions could be things that are rarely discussed.  Things like:
1) X-CS Encore - 90db, Left / Right 2 channel, paired with a sub.  Sealed.  Close to wall OK. Insert High Pass filter and you've got dynamics out the wazoo.
3) X-MTM - no sub "needed".  Ship with a pair of Fruit of The Loom socks for plugging the ports when shoved back against the wall.
4) Da Brute.
None of these are the fancy Ferraris... but they could be all you'll ever need.
Which begs the question... the Neo tweeter has limited options for those who can afford, but can't commit a big room / accommodate the setup needed for Otica, et al.  Coming up with an option to have that tweeter in a room / space / wife / workable, "full range" option that doesn't require a sub... it might be a good idea.  Especially when soft domes are on backorder.  :angel:
Now this is good stuff!  I seen how great the measurements are for the Bravo.  I haven't heard that particular speaker or the Brute.  I have listened to the encore, NX-studio and NX-treme all with open baffle subs.  Can someone who has heard the Bravo and Brute compare talk about its strengths and how  it sounds next to the encores and NX-series.
jmimac351
« Reply #94 on: 14 Sep 2023, 04:21 am »
BrandonB
« Reply #95 on: 14 Sep 2023, 02:09 pm »
I think the smart money is a great 2-way paired with subs that can be tuned for the room. The thing is, most 2-way (2 driver) speakers can't play bigger, with ease - they get compressed. Most 2-way speakers won't play to mid-30Hz, period.  I'm running a pair now that do that, with ease, and it's pretty intoxicating - especially considering the flexibility they afford for any room (add subs, if needed).  Even though I've got the subs, the inherent dynamics the speaker delivers just helps it do "the thing". The subs aren't propping the speakers up, they are adding gravy to what's already there.
Maybe the NX-Studio will play with the ease I'd want when incorporating a 100Hz high pass filter.  It's not 90db though / needs more power... And then, there's the X-MTM...
As for flexibility... what if there was a way for this ported / plays bigger with ease to mid-30Hz, Neo Tweeter 2-way to have the tweeter tuned for output with a resistor, depending on boundary reinforcement / taste... push up against a wall (resistor A), pull out from the wall (resistor B).  I have extra cigar boxes that would be a perfect home for the outboard crossovers.
That would be one versatile speaker, with the tweeter that's bragged about.  Maybe that's a Fool's Errand, but it's been interesting to play with.  In fact, I'm using something like that right now:
Are the speakers you have the the X-CS's with open baffle subs.  I know in the past they had the NX-MTM but no longer offer the flat pack's.  I'm not sure why they stop making them.
Danny Richie
« Reply #96 on: 14 Sep 2023, 06:57 pm »
This sounds like a video that I shot: https://youtu.be/aWDPieaILIg?si=79YQ-h83t7lcGmch
jmimac351
« Reply #97 on: 16 Sep 2023, 12:20 am »
Early B.
« Reply #98 on: 16 Sep 2023, 04:33 am »
One thing I have definitely learned: A 2-way that plays to mid-30Hz with a pair of subs is the business...
Yep. You should send one of those to Danny to fix and upgrade the crossover.
jmimac351
« Reply #99 on: 16 Sep 2023, 01:02 pm »
