BDP-pi: problem with USB output
0 Members and 1 Guest are viewing this topic. Read 626 times.
Calypte
« on: 25 Aug 2023, 08:40 pm »
Using USB, when I output hi-res files (anything above redbook CD resolution), I get lots of noise -- static-like sounds or white noise hiss.  My DAC is a Schiit Bifrost 2/64.  I can play these files from a Win 11 laptop through the Bifrost just fine.  I only get this noise when I use the BDP-pi with USB.  A few years ago I ran into this issue when I tried playing hi-res files through an Emotiva DAC with USB.  At the time I blew it off as an Emotiva problem.  It's not.  Everything works fine with 75-ohm coax.
Is there a setting somewhere in the menus that I need to adjust to optimize the USB output?
