NX series waveguide shape
0 Members and 1 Guest are viewing this topic. Read 900 times.
g3rain1
« on: 24 Aug 2023, 07:03 pm »
I noticed on the NX model speakers there are 2 different shapes for the wave guide. In some instances it's sides are rounded and in others they're more squared off.  I have the NX Otica and mine are the squared off kind. Is there a story behind the difference?
Danny Richie
Re: NX series waveguide shape
« Reply #1 on: 26 Aug 2023, 08:50 pm »
The ones that we have with softer edges were simply hand sanded after the CNC machine milled them out.
KTS
« Reply #2 on: 29 Aug 2023, 12:12 am »
Danny,
I was assembling the Studio’s a while back and I thought it would be cool to have the waveguide offered as a glue in insert with the flat packs. This would help when finishing the cabinets, I think Peter had mentioned it to me in a message, but it would be easer to finish the guide separately, if veneering across the enclosure front baffles. Just a thought.
Thank you, Kelly
