Tidal not functioning in BDP-2
0 Members and 1 Guest are viewing this topic. Read 708 times.
Twangbar
« on: 23 Aug 2023, 10:43 pm »
I have been using Tidal in my BDP-2 successfully for many months. Just recently, after I start up the BDP-2, and then click the Tidal in the Media Player listing, I do not get presented with the login screen, it just goes to a blank listing (see screenshot below)
I have reset the BDP to the default, but the same issue persists. I even changed my password in Tidal, thinking that may trick the BDP-2 to presnt me with the Tidal login again - no luck.
Any ideas on how to get this working again? I am running the latest firmware.
Thanks for any help with this!
Twangbar
Re: Tidal not functioning in BDP-2
« Reply #1 on: 25 Aug 2023, 11:53 pm »
Update. So the only way I could clear this issue was to unplug the unit from the wall outlet (AC). Left it for a while and then powered it up again and all is fine now.
Hope this helps anyone else who may run into this issue.
