real quick question
0 Members and 1 Guest are viewing this topic. Read 1353 times.
CornellAlum
real quick question
« on: 27 Apr 2005, 11:59 pm »
I am wondering, does anyone have a quick remedy for making accoustic paneling portable, as in stand mounted?   I am not a fan of leaving them on the walls, as one of the walls that needs to be treated BADLY, is a glass sliding door, hence the problem.  Any quick solution I can make/buy.  Heading out to the hardware store anyway and I thought I would check.
Thanks in advance!
Daryan
youngho
real quick question
« Reply #1 on: 29 Apr 2005, 11:00 am »
I'm not sure what kind of panels you're referring to. If you mean foam ones, this won't apply. If you mean cloth-covered fiberglass with wood frames, consider one of these DIY tricks for Magnepan speakers.
http://www.positive-feedback.com/Issue4/magnapan1.htm
http://www.integracoustics.com/MUG/MUG/tweaks/richardh.html
or any of the others under the Mounts section of this webpage:
http://www.integracoustics.com/MUG/MUG/tweaks/index.html
CornellAlum
real quick question
« Reply #2 on: 29 Apr 2005, 11:52 am »
Those will work perfectly.  My back wall is foam, the rest a real panels.  Now, to figure out where they are going to go:-)
Thanks again,
Daryan
Ethan Winer
  • Audio expert
Re: real quick question
« Reply #3 on: 29 Apr 2005, 02:57 pm »
Daryan,
> accoustic paneling portable, as in stand mounted? ... Any quick solution I can make/buy. >
Since you asked specifically, follow the link under my name below.
--Ethan
