0 Members and 1 Guest are viewing this topic. Read 4488 times.
Thoughts on whether the Bel Canto or something else in the $7-10,000 range would be a noticeable improvement with the Salks?
If you are using the Anthem ARC room correction especially the latest update with time correction of sub integration than the Anthem integrated will be hard to beat. I have experience with that setup in a second system. If you really spend the time with arc genesis and have subs the difference is night and day better than the sum of your gear.My personal pov- stick to what you got because it works and if you spend a ton of coin on a dac ahead of the anthem… it is still being converted to digital to perform room correction and then back to analog.
WGH... That is awesome, did I win something? Just kidding but this is a good thread with lots of people chiming in to help. I live in NC which is basically the hifi wasteland of North America so I find dealers who will ship me gear to try. Negotiate the price upfront, understand if you can use their shipping acct to return if you cannot buy the demo unit. I have done this with cables, Aurender N20 and several other pieces. So after you mess with your settings if you decide to explore new gear, limit your risk and find a dealer willing to add value and ship to you.
I wish there was a way to find out if something is going to make that "not subtle" huge difference ... in sound quality without having to buy and try new equipment.
Hapa cables will make that huge difference, often bigger than an new amp. Why? Usually cables are the bottleneck. At this level the sound is all about small differences, an average cable will obscure small low level signals like echos and subterranean bass that add realism and space to a performance. I have heard all the Hapa cables in my system, they are all subtly different and wonderful.I don't know what tours are still happening, there have been interconnect, digital and speaker cable tours. Send Pez a PM or ask in the Hapa Circle. Listen and decide in your system, free, no pressure, nothing to buy but a review helps everyone out.
Color me skeptical. I have never believed that high end cables can achieve this.
Color me skeptical. I have never believed that high end cables can achieve this. Better electronics, especially higher end integrated solutions, where expensive interconnects are not needed, IMHO, will achieve the improvements you discuss.
Many previously skeptical audiophiles treat cables as components.
