Best way to get PHONO pre for my Odyssey set up
0 Members and 1 Guest are viewing this topic. Read 11683 times.
Countrypie
Re: Best way to get PHONO pre for my Odyssey set up
« Reply #20 on: 21 Aug 2023, 08:20 pm »
@nlitworld.  THANKS!  ` my AUDIO SHOP told me to adjust the VTA ... to get more bass.   Pretty frustrating.
lazydays
« Reply #21 on: 28 Aug 2023, 06:34 am »
I use a George Wright tubed preamp going thru a Candella or a Quicksilver. Sound is wonderful, and there is no digital anything gonna smoke that combo. Cartridge is a Grado wood bodied Platinum. The current table is my trusty Acoustic Signature, but also have a couple JVC Q series tables that really sound great. The cable from the tone arm to the phono stage is critical. I use a Zu. From what you are saying, I'd investigate the tone arm and cartridge alignment. Also forget about all those numbers on the tone arm when setting tracking force. Get a digital scale, and run the force on the high side. Try adding one more gram of force as an experiment. If your using an O ring for a belt drive, get rid of the O ring!!
gary
